maintenance: forum temporarily 'read only'
Franz Neumeier
Dear friends,
steamboats.org is moving to a new webserver, physically. That means we have to shut down the mesage board on the old server for posting to avoid loosing postings in the process of moving the database.
As long as you see this message, you're still seeing the message board on the old server. The message board will be available for posting immediately after the switch to the new server has happened.
The whole process will not take longer than two or three days, most likely it'll go much faster than that.
Thanks for your patience and understanding.
Franz
P.S. I don't want to confuse you too much, but it's likely that some of you will see the message board on the new server earlier than others. That's a normal phenomenon and depends on how frequently your provider is updating its so called "DNS servers" which are reponsible for directing you to the correct server.
